Old 07-27-2019, 05:16 PM
GRAFFZ GRAFFZ is offline
Default Camaro Chevelle Corvette Nova - NOS GM Parts.
We have some NOS GM parts listed on eBay starting at .99 cents. Below are some of the items. There are even more stuff starting at $9.77 and up. All no reserve.
NOS GM 730 CCW Distributor Cam. Ebay link: https://www.ebay.com/itm/113829727231
NOS Delco yellow battery caps. Ebay link: https://www.ebay.com/itm/113832078745
NOS GM Delco-Remy Distributor 163 vacuum advance. Ebay link: https://www.ebay.com/itm/133122622768
NOS Idler Arm Mounting Bolts. Ebay link: https://www.ebay.com/itm/113829727305
NOS GM black coat hooks. Ebay link: https://www.ebay.com/itm/133124727836
NOS GM Delco Big Block 135 degree Ignition wire boot terminals. Ebay link: https://www.ebay.com/itm/133122622840
NOS GM 1969 ignition lock cylinder. Ebay Link: https://www.ebay.com/itm/113829727511
NOS Delco shock mounting washers and nuts. Ebay Link: https://www.ebay.com/itm/133122622895
NOS GM Transistorized voltage regulator mounting bolts. Ebay link: https://www.ebay.com/itm/113829727604
NOS GM (Correct Semi Clear) Windshield washer bottle. Ebay link: https://www.ebay.com/itm/133122622943
NOS GM Camaro/Nova Console gauge lens. Ebay link: https://www.ebay.com/itm/113829727686
NOS GM 1968 Camaro Front spoiler mounting rod. Ebay link: https://www.ebay.com/itm/113829727732
NOS GM headlight ring retaining screws. Ebay Link: https://www.ebay.com/itm/113829727780
NOS GM Lot of (5) NOS GM engine stop lift cables. Ebay link: https://www.ebay.com/itm/133122623016
If you win more than one item we will combine the shipping cost.
Thanks, Sam
GRAFFZ
Tags
1967, 1968, 1969, 1970, copo
