Old 09-02-2019, 08:51 PM
Edgemontvillage's Avatar
Default Pitman Arm Power Steering Cast#395227
I'm looking for a nice Pitman Arm for a 69 Z/28 Camaro with Power Steering. Casting # is 3953227. The center to center measurement is 5 3/4" and the spline opening is 1 1/8" diameter. The manual steering Pitman has the same casting # however different dimensions and is usually stamped with the letter M in the area around the spline. Please PM if you have one available, thanks. Lloyd.
