Old 09-17-2019, 12:25 PM
BLACKLS5 BLACKLS5 is offline
Default Big block Chevy oil pan ID.
Does anybody have an idea as to what the application of this oil pan may be. Looks similar to 65-69 big car but without the indentations on each side. Thanks
Attachments - The Supercar Registry IMG_20190916_191857.jpg IMG_20190916_191830.jpg IMG_20190916_191819.jpg IMG_20190916_191756.jpg
Old 09-17-2019, 05:42 PM
rszmjt rszmjt is offline
IMO It looks like a 72-75 Chevy/GMC truck pan for 2 wheel drive 1/2 & 3/4 ton:
Old 09-18-2019, 01:03 AM
Default Big Block Chevy oil pan ID
It looks like a 65 -67 Impala pan with the two stepped drop, it also has the earlier Large nut oil pan plug. But it could be an earlier truck pan. Does it have a welded baffle in the inside?Don.
Old 09-18-2019, 01:12 AM
Don, The ones I saw advertised seem to lump 1965 through 1969 together. 65-67 are different than 68 and 69? They also had indentations on each side which led me to believe this wasn't for the "big cars". Thanks
Old 09-18-2019, 11:13 PM
I believe '68 & '69 were identical except for the Smaller 9/16" nut used for the drain plug, that is why I said '65-'67 B bodies usage. I need to see the welded in windage tray also to confirm. I also noticed the hole for the front oil pan seal nipple that was peculiar to the '65-'67 BBC pans. Don.
Old 09-19-2019, 11:36 AM
Here you go and thanks for the help...
