Old 11-07-2019, 10:02 PM
1crossram 1crossram is offline
Default 1967 Camaro RS headlight motors rebuilt
I have started to rebuild the 1967 only electric headlight door motors using original factory parts. Ideally, if people sent me their headlight motors I will disassemble them and rebuild them, replacing damaged parts. Also have some stock of the heavy washers for the output arm to headlight motor shaft. Cost is $175.00 each plus shipping. Please contact for more information either here or at [email protected]. Thanks
The originals used metal gears and I'm using NOS parts.
The Following User Says Thank You to 1crossram For This Useful Post:
Niblet (11-08-2019)
Old 11-08-2019, 03:38 PM
Niblet Niblet is offline
Banned
I thought the factory parts had plastic gears? do you use heavy duty gears and what not?
Old 11-08-2019, 09:20 PM
The gears from the original motors were many and all metal, no plastic. The housings are tough plastic. I pull the motors apart and clean all the gears in an ultrasonic cleaner, then dry each gear by hand. When I get enough parts together to build a gear set I put one together and then concentrate on the small electric motor portion. Thanks for your interest.
1967 Camaro RS/SS convertible Butternut yellow with black power top, factory AC
Rebuilding 1967 RS headlight motors
Old 11-09-2019, 11:25 AM
Banned
well I will buy a rebuild set from you if you have one available
Tags
1967 rs, headlight, motors
