Old 12-29-2019, 02:06 AM
Slob44 Slob44 is offline
Default 1969 Chevelle starter solenoid wire clip
Need a picture of the correct clip that holds the starter wires on a 1969 Chevelle SS with a turbo 400. Any help would be greatly appreciated
Old 01-03-2020, 03:17 AM
PM sent
Bill Pritchard
Old 01-03-2020, 05:27 PM
pm sent
Old 01-03-2020, 10:05 PM
tunes's Avatar
tunes tunes is offline
Would it be different on an automatic car vs a 4 speed Chevelle? I've never had a '69 SS Chevelle with the automatic transmission and am curious to what is different.
Robert
_______________
2023 Stingray Coupe Z51
Old 01-03-2020, 10:59 PM
My assumption is based on the starter heat shield ...the info I have seen, the 4 speed cars have the heat shield and the automatic cars did not. So I am making the assumption that the wire clip would be different. I believe there are 2 clips, one for the heat shield and on non heat shield cars. Any help greatly appreciated
Old 01-04-2020, 02:30 AM
I think the reason the 325hp automatic cars did not have the heat shield around the starter is because they had the sheet metal heat stove around the passenger side exhaust manifold. The heat stove acted as a form of heat shield and also provided heated air to the carburetor via a flexible duct to the air cleaner snorkel. I don't know if the 350hp and/or 375hp cars with automatic had any form of a heat shield for the starter or not. They both used the open element air cleaner and hence there was no practical means of providing heated air to the carburetor, making the heat stove unnecessary.
Bill Pritchard
