Old 01-18-2020, 12:13 AM
R68GTO R68GTO is offline
Default Front inner fender washer finish
What's the correct finish for the big round washers you see on the wheel side of the inner fender? - 69 Camaro.
ruralrte66 (01-18-2020)
Attachments - The Supercar Registry Lacquer dipped inner fender washer 4ea..JPG Fender Washers.JPG
Old 03-12-2020, 05:41 PM
The originals I have removed were always dipped in black paint... the reproductions are zinc plated, which I just dip in black paint.
Pictured here you can see on this original car, the paint pooled on the upturned edge of the washer when dipped.
Old 03-12-2020, 05:43 PM
m22mike's Avatar
m22mike m22mike is offline
Agree, ones I have media blasted were lacquer dipped
Mike
The Following 2 Users Say Thank You to m22mike For This Useful Post:
JBALL (03-20-2020), Woj (03-12-2020)
Old 03-14-2020, 10:47 AM
Mike
Thanks for the info guys. I had to laugh when I read the last two posts because I had a bitch of a time getting that clod of "stuff" cleaned out of there when stripping my washers. Had I known that clod was supposed to be there, I could have saved myself some time - just never dawned on me it could be paint that was supposed to be there
As always I appreciate the info, now I need to go back to these parts and add a clod of paint!
The Following 2 Users Say Thank You to R68GTO For This Useful Post:
enio45 (03-25-2020), m22mike (03-14-2020)
Old 03-14-2020, 12:35 PM
m22mike's Avatar
I have had globs of paint on rims so thick I had to use a propane torch and a scraper to remove it.
I think most all vendor supplied parts were dipped, even radiator core supports. It was quick, no primer, and did not waist paint from overspray
Mike
Old 03-14-2020, 04:37 PM
This is a part of the restorers conundrum. Many parts like A-arms were dipped with runs and drips. Do you reproduce that with a vat of paint or do you spray with the masked off areas where they hung the parts through the dipping process but then not get the runs and drips? Part of being "over restored" I suppose.
Owned since 1978 - First Car
Old 03-17-2020, 01:32 PM
I put the thinned paint into an old syrup bottle with the small opening and then use it to "pour syrup on the a-arm" over a tray then recycle to paint -filtering it when I pour it back into the syrup bottle.
The Following 2 Users Say Thank You to firstgenaddict For This Useful Post:
BCreekDave (03-17-2020), napa68 (03-25-2020)
Old 03-20-2020, 05:32 PM
Kurt S Kurt S is offline
They floated the paint on water. Pretty easy to duplicate....
Kurt S - CRG
Old 03-20-2020, 06:26 PM
Yes, with oil based lacquers and enamels. Don't try with water based paints!
But really reproducing the methods the factories used is functionally impossible. Anyone care to reproduce the "red river" that Norwood used to apply the red oxide primer base?
But trying to do it best is part of the fun, correct?
Old 03-25-2020, 01:34 PM
IF you float it on water, you cannot use tap water, you need to use de-ionized water.
Also Floating it on water requires aLOT of paint, if you are not doing the parts for multiple cars at one time the amount of paint you would waste would be cost prohibitive.
