Old 01-21-2020, 01:24 PM
Crossbreed383 Crossbreed383 is offline
Default Exhaust head pipes
Hello all,
Does anyone make a nice set of 2-1/2" exhaust head pipes for stock manifolds for a 68-72 Nova ?
mandrel bent preferably as well. The ones I have found are all listed for SB application.
Thanks in advance
Custom Cam /Engine Dyno and Spintron Operator at Brian Tooley Racing R@D
84 Mustang/Hertz Rent-a-Car
438CI 5.58@123 8.80@147 On Radials ALL MOTOR
Powered by my 13 year olds engine program
68 NOVA 396-375 HP F.A.S.T. Project
Old 01-21-2020, 02:10 PM
John Brown's Avatar
Terry Pennington made a complete ex system using mandrel bends from JC Whitney for his wifes Corvette. Made up a flare piece to attach to the manifold, but the rest of the exhaust system was made using Whitneys mandrel bends and straight pipe between the bends. If you plan ahead, you can get the correct bends to slip over each other so you don't have to butt weld anything.
John Brown
Old 01-21-2020, 04:22 PM
YENKO DEUCE REGISTRY's Avatar
I would check out the Pypes System.....
Marlin
