Old 02-04-2020, 01:05 AM
ALLZS ALLZS is offline
Default paint removed off plastic
any one know of a good way to get spray paint off a plastic fan shroud with out hurting the plastic
Old 02-04-2020, 01:10 AM
A white scotchbrite pad,dipped lightly in paint thinner.If not work,go to the more abrasive green pad..if not work,go to even more abrasive black pad.
If not work,go back to the white pad & dip in the ever powerful Goof Off,then work up to more abrasive pads again.
Wear gloves as Goof Off will melt the scotchbrite pad & shroud if left on long enough.
Old 02-04-2020, 03:27 AM
Lacquer thinner will damage a lot of different types of plastic. I've used non-acetone nail polisher remover several times to take off rattle can spray paint on plastic items. It takes a lot more work to get it off but its never damaged any plastic I've used it on so far.
The Following User Says Thank You to carnut4life For This Useful Post:
Woj (04-13-2021)
Old 02-04-2020, 03:51 AM
clnovaparts clnovaparts is offline
Use Super Clean. The purple gallon container. Submerge the part for best results. Plastic model builder hobbyist use it. Check out YouTube videos. Won't hurt plastic. Don't get it on your skin. Great for stripping vacumn plating (chrome) on arm rest bases, AC balls etc. Read the directions on what not to use it on.
Old 02-04-2020, 05:54 AM
169indy's Avatar
169indy 169indy is offline
Try a small spot using DOT-3 brake fluid and see how the results are.
I used this method to remove factory paint from Athearn Model Railroad painted locomotives during a livery change.
Jim
69 Los Z11
68 SS/RS 396/325
68 Los Z28
Old 02-04-2020, 11:23 AM
bbbentley's Avatar
Oven cleaner
FULL OWNER HISTORY
The Following 3 Users Say Thank You to bbbentley For This Useful Post:
John Brown (04-13-2021), PeteLeathersac (04-13-2021), Rainer (02-04-2020)
Old 02-04-2020, 12:22 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I powerwashed mine off. Looked like new after.
Old 02-04-2020, 01:18 PM
By the way, a propane torch with a wide fan type flame spreader can be used (with care) to remove light scratches on the shrouds. Practice on the inside of the shroud.
Owned since 1978 - First Car
Old 02-04-2020, 01:39 PM
Burd's Avatar
Burd Burd is offline
Find another, sell It at the swap. Lol
I believe it was xylol the sign shop used where I used to work.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 02-04-2020, 07:34 PM
Rainer Rainer is offline
Originally Posted by bbbentley View Post
Oven cleaner
I second this. I have used it for years on various plastics, including tail light lenses with no effect on the plastic surface.
1969 Chevelle SS396 L78 M22 4:10 Tuxedo Black
1970 LS3 Malibu 400 BB convertible
1970 LS3 Malibu 400 BB coupe
1970 Chevelle 300 series LS3 400 BB coupe, special order Monaco Orange
1970 Chevelle Concours Estate LS3 400 BB wagon
1970 Chevelle SS396 L78 M21 3:55 Tuxedo Black
