Old 02-09-2020, 04:37 AM
Default Nova BB Power steering hose routing
Does anyone know the proper routing for the power steering hoses in a 69 big block Nova? I have them going under the engine, by the oil pan, and below the motor mount stand. Not sure if this is correct. It seems to stretch the hose a bit. Photos are always welcomed. Thanks BR
69 El Camino
69 Nova
C7 Vette
Old 02-09-2020, 12:36 PM
bbbentley's Avatar
Bill, I would think it would be the same as a 69 Camaro? Almost positive that it is. Sounds like what you describe is the right routing. On a factory setup (Camaro anyways), there is a hose loom that goes under the engine frame stand attached by the lower bolt that holds both hoses against the frame and directly below that left frame stand.
FULL OWNER HISTORY
Old 02-09-2020, 12:39 PM
earntaz earntaz is offline
I am interested also as I do not know if I have them right on my BB Nova. Does anyone have good images? Thanks ... TAZ
Old 02-09-2020, 04:10 PM
MarcDant's Avatar
MarcDant MarcDant is offline
This pic is from the gm product info. program.
Old 02-09-2020, 06:38 PM
That looks like what I need except it's a small block. Probably the same as big block though. Thanks for all he feedback guys....
69 El Camino
69 Nova
C7 Vette
Old 02-09-2020, 07:19 PM
You will need the clip that attaches to the lower motor mount bolt to keep them in place.
- Warren
Old 02-09-2020, 08:56 PM
Unreal Unreal is offline
69 SB Camaro, and 69 BB Camaro are not the same. I'm pretty sure Nova and Camaro are the same, but not absolutely sure. I am sure that on the Camaro, SB, the return hose connects into the back of the reservoir, but on the BB, it connects into the side of the reservoir. That's a 69 model year, only. Not sure if late 69 Camaro started using the new more tear drop shaped reservoir, or if the round reservoir was used for the extended model year.
