Old 02-29-2020, 10:05 PM
68bronze 68bronze is offline
Banned
Send a message via AIM to 68bronze
Default Valve covers
Looking foe a new set of chrome 396 valve covers to clear crane roller rocker arms that looks like close too stocks one,s
Old 02-29-2020, 10:44 PM
wvhylander wvhylander is offline
Whats hitting the valve cover the rockers or the poly locks? I have Comp Cams Ultra Pro Magnum rockers and they don't hit the covers. The Poly locks on the exhaust rocker hit the covers wouldn't let the cover sit down flat on the head. I used a 5/16ths thick gasket and had the 4 exhaust poly lock hex head cut to about half the original thickness now the valve covers set down and seal.
A friend had the big boxy aluminium rockers he had to grind a corner down on the rear rocker arm to clear the factory valve cover.
Old 02-29-2020, 11:07 PM
L_e_e's Avatar
L_e_e L_e_e is offline
I bought some cheater valve covers from NYrestomod on eBay for one of my cars, they are identical to stock chrome valve covers except they come in either 1/2" or 3/4" taller than stock and they clear Crane gold aluminum wide body rockers and lock nuts. They are also a pretty nice part, much thicker than the typical Chinese knock off valve covers.
The Following 2 Users Say Thank You to L_e_e For This Useful Post:
68bronze (03-01-2020), HawkX66 (03-02-2020)
Old 03-01-2020, 04:56 PM
X 2 for the Cheater valve covers from NYrestomod. Nice product, I have a set also for my Monte Carlo.
Old 03-01-2020, 11:50 PM
ruralrte66 ruralrte66 is offline
Has anyone used these with the stock 396 A/C brakets on a 69 car? Trying to keep my original SS 396 Elcamino looking stock.
Thanks Gregg
Old 03-02-2020, 01:11 PM
L_e_e's Avatar
It should work with that over the valve cover AC bracket, but you probably will have to slightly rotate the compressor away from the engine using the bracket adjustment slots and use a slightly longer belt to get the clearance.
