Old 03-05-2020, 06:52 PM
wayoutz's Avatar
wayoutz wayoutz is offline
Yenko Premier Member
Default Nos battery Prep
Hey folks
I have a question on using an original NOS delco battery that's still factory sealed.
Using a NOS Delco Y87 and need to know what to do with the factory hole filler delco puts in each hole. Looks like a wax or plastic but do I need to pull these out or just push them in and fill the battery.
Old 03-05-2020, 07:13 PM
I don't see a pic attached.
Old 03-05-2020, 07:26 PM
wayoutz's Avatar
picture size to large to post.
Old 03-05-2020, 11:50 PM
Burd's Avatar
Burd Burd is offline
Use the medium size. If someone would just modify the pic size on the site.
It's only Orig once
waste all the rest.
1978 Y88
1995 Q45
Old 03-06-2020, 12:00 AM
Z15 SS 454 Z15 SS 454 is offline
Thread hi jack, Sorry....
Burd is that a fricken mask on your sig picture? AWESOME!!
/Users/iancote/Desktop/MVI_0921.AVI
1970 L78 Nova Best ET 9.14@152 MPH Street trim
1970 L34 Chevelle Matching #s Project
1970 LS6 Chevelle Matching #s Project
2001 LS1 Camaro SS SOM Stock
2008 LS3 Sierra Denali Blk Stock
Old 03-08-2020, 05:33 PM
Just push them into the battery, I bought a NOS battery for my Corvette last year pushed in the wax plugs and filled it with acid.
Works great...
When it kicks the bucket I am going to put a gel battery inside it.
Old 03-08-2020, 06:14 PM
jl8z28 jl8z28 is offline
I heard there's places that can rejuvenate them
Old 03-08-2020, 09:03 PM
I read about something in the last 5 years which was being used on lead acid batteries as well, IIRC apparently there is a way to strip the plates using either electrolysis or chemical and electrolysis. (reverse the polarity or something) I know that lead is used in some type of plating process so there may be a way to remove the outermost layer of lead oxide? to expose fresh lead?
Just guessing here... I am in no means a chemical or electrical engineer.
Old 03-08-2020, 10:05 PM
I but a Braille battery inside mine. Works great. I was warned that the Braille batteries do not hold a charge long term. My experience has been just the opposite. I have two. I had one set in the car for 6 months without driving it or charging it. I put my battery tender on it, and it was fully charged within an hour. If I let my lead acid batteries sit even 30 days, it takes 12 - 24 hours to fully charge.
Old 03-09-2020, 03:00 AM
Kurt S Kurt S is offline
James,
You are probably thinking of this: https://www.pulsetech.net/our-techno...echnology.html
It works. I've saved several batteries that couldn't even hold a charge. Won't fix them all, but will many.
Kurt S - CRG
