Old 05-23-2020, 09:50 PM
Caseys69 Caseys69 is offline
Default 69 Chevelle JD Block and Heads
Up for sale is a 69 Chevelle 4 bolt main 396 block and heads. Specs below....
EVERYTHING IS GOING TO BE MAGNAFLUXED AND THE BORE WILL BE MEASURED SUNDAY OR MONDAY AND I WILL FURTHER UPDATE THIS THREAD.
I just wanted to get this posted while i have time
$1250
272 Block
Date- I 16 8 Sept 16 1968
Suffix- TO920JD
VIN by Oil Filter- 19K3?6459 (what it looks to be)
One pair is $1200
One Single is $600
You can pick the dates you want for the pair or the singles
840 Heads (3 available) 2 stay as a pair and 1 can be bought as single
I 5 8 September 5 1968
I 10 8 September 10 1968
I 16 8 September 16 1968
Location- La Grange Park, IL 60526
Best form of contact, Call or Text 708 287 2914
IMG_3809 by Casey Kloess, on Flickr
IMG_3810 by Casey Kloess, on Flickr
IMG_3812 by Casey Kloess, on Flickr
IMG_3813 by Casey Kloess, on Flickr
IMG_3814 by Casey Kloess, on Flickr
IMG_3815 by Casey Kloess, on Flickr
IMG_3816 by Casey Kloess, on Flickr
IMG_3817 by Casey Kloess, on Flickr
IMG_3818 by Casey Kloess, on Flickr
Old 05-23-2020, 09:51 PM
IMG_3824 by Casey Kloess, on Flickr
IMG_3825 by Casey Kloess, on Flickr
IMG_3826 by Casey Kloess, on Flickr
IMG_3827 by Casey Kloess, on Flickr
Old 05-23-2020, 09:53 PM
IMG_3829 by Casey Kloess, on Flickr
IMG_3830 by Casey Kloess, on Flickr
IMG_3831 by Casey Kloess, on Flickr
IMG_3832 by Casey Kloess, on Flickr
IMG_3833 by Casey Kloess, on Flickr
IMG_3834 by Casey Kloess, on Flickr
Old 05-24-2020, 02:03 AM
SS69chevelle SS69chevelle is offline
based on the block assembly date, it is likely K316459 makes the chevelle a 09D or 09E build. good luck with sale.
Andy
Team Chevelle #3135
ACES #08305
1969 Chevelle Trim Tag Research (On-going)
The Following User Says Thank You to SS69chevelle For This Useful Post:
Caseys69 (05-24-2020)
Old 05-25-2020, 06:38 PM
All heads magged out good.
Old 05-25-2020, 06:56 PM
L72Chevelle L72Chevelle is offline
block update?
Old 05-27-2020, 01:28 PM
Block is pending sale. It did mag good.
