Old 07-06-2020, 01:10 AM
207 207 is offline
Default TCS solenoid
Hi everyone. Just purchased a 1970 W-31 4 speed car. It has the tcs solenoid on the side cover, but is not connected. My question, am I able to run the with it not connected? Haven’t been been able to find the wire anywhere that would be it. The trans is not the matching number for the car. Thanks in advance. Gene.
Old 07-08-2020, 12:10 AM
YENKO DEUCE REGISTRY's Avatar
Yes, you can run without the wire attached to the pin switch in the trans sidecover, but just make sure your TCS solenoid on intake is also bypassed. Make sure the dist vac advance is plugged directly into full intake vac - usually via the base of the carb.
Marlin
Old 07-08-2020, 12:18 PM
bluel78 bluel78 is offline
Do you have any pics of your W31? That's my dream car.
