Old 07-26-2020, 06:05 PM
wthirty1 wthirty1 is offline
Question How to recreate blue for RWL tires
I recently finished restoring my original G70-14 Polyglas spare tire for my Olds. The tire came out looking as mint as a 50 year old tire possibly could. How can I "recreate" the blue that went over the raised white letters? Does anyone know what the tire manufacturers use? I know...strange request. Thanks in advance.
1970 Cutlass S W-31 - platinum, blue stripes, blue buckets, M14 3-spd
1970 Cutlass Supreme Y74 Pace Car #79 - IU Little 500 Pace Car
1970 442 - white, red stripes, white buckets, M21 4-spd
Old 07-26-2020, 06:40 PM
L_e_e's Avatar
L_e_e L_e_e is offline
Dish soap and blue chalk powder used in a chalk line looked pretty good.
The Following User Says Thank You to L_e_e For This Useful Post:
olredalert (07-26-2020)
Old 07-26-2020, 11:14 PM
Interesting. I'll check that out. Is that how they do it at the tire plants?
Old 07-27-2020, 12:24 AM
L_e_e's Avatar
I seriously doubt that's how they do it.
But I think the reason why they do it is to not have the black side of a tire discolor the RWL's when stacking tires.
Anyways, it is what I came up with years ago to do what you are doing now and it came out pretty close, But I'm sure there are many other ways to achieve the same thing. I was mostly concerned with being able to remove the blue easily and without discoloring the RWL's.
Old 07-27-2020, 12:44 AM
John Brown's Avatar
White sidewalls also had the blue protecting them. Maybe a blue food coloring would also work. For sure the covering was just a soap based product. I found that when I installed new tires not to use anything other than water and a brush to remove it. Using any type of cleaner left tiny black dots on the white.
John Brown
Old 07-27-2020, 12:48 AM
Viz Viz is offline
Tire mounting lubricant. if you can still find any in blue, sometimes works. Slobber it over the lettering and let it dry.
Old 07-28-2020, 12:40 PM
napa68 napa68 is offline
Great eye for detail! I never would have thought of that.
Tim
Old 07-28-2020, 02:02 PM
SMS SMS is offline
Tim
That is a good one. Hello spare tires... here I come.
Old 07-28-2020, 03:48 PM
I was reading on another forum about the bluing used on WSW, RWL tires. Someone who actually worked in a tire manufacturing plant said it was a a polyvinyl alcohol solution tinted blue. Amazon sells the tint:
https://www.amazon.com/Brilliant-Cre.../dp/B07JM4SPFY
Old 07-28-2020, 11:41 PM
wheelhop wheelhop is offline
Polyvinyl alcohol 1.4% is an eyedrop / eye lubricant used in visine and other brands
