Old 08-06-2020, 10:40 PM
jasonL78 jasonL78 is offline
Default 1970 BBC valve cover tabs
Did 1970 bbc use different valve cover mounting tabs. I have 14 tabs 4 short early style 10 longer? If this is correct where do the 4 short tabs go? Bottom middle 2 studs?
Looking for the next project.
Attachments - The Supercar Registry s-l640.jpg D40B222B-E06F-47AD-A7FA-4F57E35DDC95.jpeg 46C515E9-B36F-4824-A121-4C2F00B35453.jpeg
Old 08-07-2020, 01:05 AM
DWR DWR is offline
My 70 SS Chevelle 10C build had all the short style tabs on it.
Old 08-07-2020, 01:30 PM
----Not sure where the factory used those long tags,,,maybe truck?......Bill S
Old 08-07-2020, 02:29 PM
Was thinking they may be aftermarket but just wanted to clarify.They were in a bag with a bunch of parts from a 70 BBC I was thinking they were original. I will just go with the smaller tabs.
Old 08-11-2020, 02:38 PM
Enoch Enoch is offline
Banned
No those are not factory. All 70 big blocks used the triangle shaped retainers.
Old 08-13-2020, 01:08 PM
Starship Starship is offline
Those look like modified Corvair valve cover retainers. We used to do that "back in the day" on drag cars. It helped to keep the flange flat on covers that were removed often.
The Following User Says Thank You to Starship For This Useful Post:
earntaz (08-13-2020)
