Old 08-15-2020, 04:42 PM
GRAFFZ GRAFFZ is offline
Default 67-70 Camaro Z28 NOS GM Motor Mounts, Clutch Disc, Wires, Dipstick, Oil Cap, Rockers.
Collection of Camaro Z/28 nos gm parts up for auction on eBay.
Attachments - The Supercar Registry Z28Parts#1A.jpg Z28Dipstick#1B.jpg Z28Dipstick#1A.jpg Z28ClutchDisc#1A.jpg
Old 08-15-2020, 04:48 PM
Default Collection of NOS GM Z/28 parts.
(2) NOS GM engine motor mounts. Locking style with green paint marks as well as
GM parts #s embossed on the sides. These fit the Z/28 as well as Big Block engines.
They have some surface rust in spots as well as shelf wear, otherwise are Brand New.
1969 Camaro (302, 350, 396, + COPO 427).
1970 Camaro Z/28 (LT-1 350).
1969-1970 Chevelle + El Camino (396 + 454).
1969-1970 Nova (396).
****************SOLD******************
NOS GM Clutch Disc assembly. It is 10.50" inches in diameter and has brass rivots.
High quality factory GM OEM clutch that was manufactured by Borg and Beck back in the day.
1967-1969 Camaro Z/28.
NOS Delco Packard V8 Ignition wire set. Orange High Temp SS-550 stainless steel core wire
"cut to fit" set. These have the correct 90 degree boots for Chevrolet small block engine.
Tailor these to correctly fit your car.
1967-1970 Camaro Z/28 (302 + 350).
NOS GM Camaro Z/28 dipstick. Hard to come by early design with the flat metal loop.
The GM part# is stamped on the side. Dipstick is stamped "USE SE ENGINE OIL".
The back of the handle has s few rust spots. It also has a very light rust type film on it.
1969-1970 Camaro Z/28 (302 + 350).
NOS GM chrome oil filler cap with the correct "S" in the middle rivot. Fits 1967-1970 Camaro Z/28.
Also used on the 396, COPO ZL-1 427, + LS-6 454 Special High Performance Big Blocks.
The chrome plating is exceptional. MINT NOS condition.
1965-1969 Camaro, Chevelle, Impala, + Nova (302, 396, + 427).
1970 Chevelle, Camaro (Z28) LT-1, + Nova (Sp/H/Perf 350, 396 + 454).
1968-1969 Corvette (427).
1969 Corvette with H/Perf + Sp/H/Perf (350).
(5) NOS GM engine rocker arms. Hard to come by correct original early design with "O" embossed
and polished valve contact area. The sides on these have some minor surface rust in spot,
otherwise very usable.
NOS GM ignition coil mounting bracket. Opened the box for the first time to take PICs.
Excellent NOS condition.
1968-1969 Camaro Z/28 (302) (Except cowl induction hood).
1968 Chevelle (327) (with Special High Performance).
1968 ChevyII Nova (327) (with Special High Performance).
Thanks, Sam
Tags
302, jl-8, trans-am racing, z/28
