Old 09-17-2020, 07:20 PM
scuncio scuncio is offline
Default '70 GTO Judge
This might be a cool driver/project if the seller has some room in the price. Originally Copper, resprayed white...looks pretty good as is. Cool options, too...safe-t-track, HD cooling, special suspension, close ratio box, special order gear.
Link to 1970 Judge auction
2423701107223
69b5bee (09-18-2020), flyingn (09-17-2020)
Attachments - The Supercar Registry Screen Shot 2020-09-18 at 9.43.39 AM.jpg
Old 09-18-2020, 01:27 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Oshawa, Ontario built car too so WT1 code should be stamped into the trim tag and GM of Canada docs are available for it. Those docs should specifically call out whether this car had 3.90s or 4.33s ordered cuz it was one of 'em. Hopefully that coded nodular rear is still with the car because they are like hen's teeth and expensive. Side-note: an inordinate number of Judges from Oshawa seem to have been built with the M21 and 3.90s rather than the more mundane standard M20 and 3.55s.
I ain't nobody, dork.
Old 09-18-2020, 01:45 PM
Tracker1's Avatar
Palamino Copper
The Following User Says Thank You to Tracker1 For This Useful Post:
Xplantdad (09-19-2020)
