Old 10-16-2020, 07:49 PM
chris slawski chris slawski is offline
Default 1969 Camaro L78 4 speed CA car
Up for sale
****Please read ENTIRE ad****
California built car
Fathom green black gut
NO X Code
This car was a shell with interior and disc brake set up when I got it, front harness in the trunk, no brake lines or fuel lines original engine and trans were LONG gone.
Based on my research through both Yenko.net, and the Camaros.org web site this is what I know 100%
Factory power disc brakes are still on the car booster and calipers
Original big block heater core is still in the car
Original 4 speed big block cross member is still in the car
The original fuel tank has 1 line and it is 3/8 inch diameter, I had to drop the tank to find out.
The original dual exhaust brackets are still on the car
When I sanded some of the blue house paint off the tail panel it is black….NOT fathom green
The car still wears it’s original side gills, well on is still on the other is off the car
Condition of metal overall GOOD
Drop offs are good
Does need full trunk pan has hole for a sump (?) and prior fiberglass in well
Original doors are very nice and have never been off the car
Rockers are excellent
Floor is very good but trans tunnel was hacked
Dash has dent and cut on passenger side ( I would replace the dash)
Package tray good but cut for speakers
Rear deck filler is shot
Front fenders have rot at bottom but straight
Hood is good but not sure what may or may not be under the paint
Seats are in very good shape, driver seat has a split on window side seam otherwise very good
Headiner has a cut so needs replacement
Have full set of original standard seatbelts
Kick panels are in good shape, not cut for speakers
Have all trim and moldings including NOS rocker trim
All AMK hardware kits for engine, interior, body and chassis
The wheels and tires pictured go with the car…they are NOT dated, or coded correctly, but roll very nice and hold air.
NOW FOR THE GOOD PART!!!!
I have a complete, but apart correct L78 4 speed coded engine that goes with the car
and when I say complete:
Correct block
Correct crank
Correct heads
Correct intake
Correct NOS exhaust manifolds
Oil pan
Dip stick
Oil check tube
NOS non dated carb in box
Survivor CORRECT valve covers
Survivor correct air cleaner
Correct original engine frame mounts
New repo chambered exhaust in box with hangers
All new brake and fuel lines in box with ORIGINAL clips in box from In Line Tube
New fuel tank, sending unit, and harness
Original CORRECT radiator (needs core)
The car does have a correct 12 bolt rear BUT the date is very far off.
I have also complete rebuilt with original shifter M20 transmission bell housing clutch linkage…everything ready to go.
Basically I have all the correct original / survivor parts to make this car a better L78 than any NON survivor 100 point car out there
Included in the sale are the following AMD replacement panels
Full trunk pan
Rear deck filler
Rear package tray
Classic Industries Trunk gutters
This package and I am sure I am missing some items is $35,000
I also have available SEPERATELY a correct, not right date, but correct BV rear with GM posi and GM 4.88 gears ready to bolt in. will only sell if car goes.
AND NOW FOR THE ICING!!!!
I have the following NOS panels also available SEPERATELY BUT only as a complete package
Header panel
Cowl hood
Lower valance
Fender extensions
Standard (black) grill
Left and right fenders in box
Left and right door skins
Left and right quarter panels (2 sets, but one pair is only good for patch panels)
Trunk lid with spoiler holes
Spoiler
Tail light panel
Cowl panel
I will only sell the sheet metal if the car goes
My Name is Chris
Ebay handle Gozling1 if you want to look at seller feedback
Cell number is 609-605-5368 until 9 pm please…I am old…and fat.
I cannot deal with a transport company to help load, too many bad experiences, also you are going to need a 2nd truck for all the parts.
I can help you push into your enclosed flat floor car trailer
Chris Slawski
69 Nova
69 Malibu
69 Camaro RS
69 Camaro SS 396
The Following User Says Thank You to chris slawski For This Useful Post:
John (10-19-2020)
Attachments - The Supercar Registry 1 aaaa.jpg 1 aaa.jpg 1 a aaaaaaaa.jpg 1 a aaaaaaa.jpg
Old 10-16-2020, 08:02 PM
Also consol with gauges
Additional gauge cluster with clock and correct L78 tach
Chris Slawski
69 Nova
69 Malibu
69 Camaro RS
69 Camaro SS 396
