Old 11-24-2020, 09:46 PM
Default Best way to clean Aluminum intake???
Hey guys, I am making great progress correcting incorrect items on my real 4K '67 L78 Camaro. Ordered correct valve covers from Crane, correct carb, clamps, etc.
Question is, what is the best way to clean the intake manifold without removing it from the engine? I don't want to remove it as there are no leaks and it isn't that bad, just wondering if an SOS pad or some other technique would help me clean it while still on engine???
This is a "before" picture. Thanks!
Paul
'62 Bel Air 409/409
'68 L72 Biscayne
'69 L78 Nova
'17 Denali 3500HD
Attachments - The Supercar Registry DD3FC53B-5556-46C0-97BA-5199CC001F49.jpeg D1649B18-FC5E-40B1-B0F4-C615CEAC6CEB.jpg camaro L78.jpg C5E8ABB1-595A-41AD-A7DB-2BE8EA10E536.jpeg
Old 11-24-2020, 09:49 PM
Burd's Avatar
Burd Burd is offline
I did the bay in my buddy’s 70 Z, LT1, I heard walnut shells, but he didn’t want to remove it, I used Eastwood bare alum paint, it looked great.
Thermo, carb and dist were off. His thermo was orange.
It's only Orig once
I spend a lot of money on Wine, Women and Cars, I waste all the rest.
Old 11-24-2020, 11:28 PM
On the engine?..Paint thinner and a WHITE scotchbrite pad.Avoid any other color.
Wear rubber gloves,soft towel/pad over both fenders,and be prepared to lean forward for about an hour.
SeattleCarGuy (11-25-2020)
Old 11-24-2020, 11:58 PM
cook_dw's Avatar
cook_dw cook_dw is offline
I actually use the blue scotchbrite pads and Meguiars aluminum wheel cleaner. Seems to work for me to this point. As always do a test before diving into any cleaning project.
The Following 2 Users Say Thank You to cook_dw For This Useful Post:
SeattleCarGuy (11-25-2020), SS427 (11-25-2020)
Old 11-25-2020, 02:00 AM
Looks excellent Darrell and I have an old intake spare I could play with lol. The surprise was how you were able to get in the crevices.
68,69&2015 Z/28's
Few Corvettes
The Following User Says Thank You to 68camaroz28 For This Useful Post:
cook_dw (11-25-2020)
Old 11-25-2020, 02:04 AM
1971ls6's Avatar
1971ls6 1971ls6 is offline
Brake cleaner to get the dirt and grease off and then some oooo steel wool very lightly, if you rub too hard it will get shiny, less is more.
Since covid, I have found that the water thin hand sanitizer works great for cutting grease and best of all, removes the gas smell from your hands better than soap
The Following User Says Thank You to 1971ls6 For This Useful Post:
Old 11-25-2020, 02:35 AM
Oven cleaner is one of the best things for removing oils and cooked on greases from iron or aluminum...
To get into the pores of the aluminum use a round stiff bristled brush and wrap tape around the bristles so that they stick out about 1" that way they don't jump all around and you can work it around and get into the pores.
Here is the intake before and after on my survivor LT1.
The Following 2 Users Say Thank You to firstgenaddict For This Useful Post:
cook_dw (11-25-2020), SeattleCarGuy (11-25-2020)
Old 11-25-2020, 02:38 AM
I use carburetor cleaner on a rag to remove gas stains. Be careful about what you get it on. It can damage some plastics and may soften paint.
Old 11-25-2020, 03:37 AM
John Brown's Avatar
And oven cleaner will make aluminum turn blackish if left on too long. Timing is everything.
John Brown
Old 11-25-2020, 03:45 PM
1971ls6's Avatar
I have used oven cleaner to take off plating before black oxid, that stuff will melt an alluminum cigar tube in under 30 minutes, be careful
