I am restoring and installing a tilt column in my 68 Z28. I have run into a roadblock in getting the tilt column dismantled. I have done a dozen 70 and later columns but this is a first attempt at a non locking column. Can anybody direct me to a correct diagram or resto thread.
Paul
1971 W30 convert, triple green,second owner. 1971 W30 Convert, special order Rally red, under resto. 68 Charger R/T, Bullitt Replica 68 Camaro Z28,Corvette Bronze,Houndstooth www.vancouverclassiccars.com |
PM sent.
Give these pages a look over: http://jimshea.corvettefaq.com/?cat=10
The Following User Says Thank You to parkbrau For This Useful Post: | ||
NorCam (12-23-2020) |
Thanks for the help. The tip that I was looking for was that a puller is necessary to trove the collar to access the mechanism.
you need Kent Moore J-22598 to get the collar off.
https://picclick.co.uk/Kent-Moore-J-...326403184.html |
I tried today with a claw puller but the case tapers around the back of the collar. Looking for a good diagram that shows how a puller is supposed to attach.
the curved 'jaws' fit under the rolled upper lip of the collar. i've used the tool and it works.
