Old 01-13-2021, 10:53 PM
Default Y55 Battery
I just finished making my repop version of the Y55 battery today. I had made one just over a year ago for my 68 Z28.
It looks pretty good and started with a R59 Topper, so I had to flip flop the + and the - on the topper for the Y55 battery has the reverse polarity. The positive is on the fender side vs the radiator side.
Had to re-paint the caps yellow and drill the center of the lettered cap to install a glass eye as the originals.
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
The Following 2 Users Say Thank You to luv2sixty9 For This Useful Post:
cruiserofland (01-13-2021), PeteLeathersac (01-14-2021)
Attachments - The Supercar Registry y55 b6.jpg y55 b5.jpg y55 b4.jpg y55 b3.jpg
Old 01-13-2021, 11:10 PM
crownstables crownstables is offline
Good evening - I have a '69 4C Z28 - which battery would have come in my car from the factory?
Thanks
Old 01-13-2021, 11:16 PM
Probably the Y77 side post battery on a 04C build, but not 100% sure. Maybe someone with more knowledge on batteries can chime in. Sorry....Dave
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 01-13-2021, 11:18 PM
cruiserofland's Avatar
cruiserofland cruiserofland is offline
Beautiful work on your battery topper! Great thread from CRG on the subject: http://www.camaros.org/forum/index.php?topic=1538.0
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following User Says Thank You to cruiserofland For This Useful Post:
luv2sixty9 (01-13-2021)
Old 01-13-2021, 11:30 PM
Dave, can I ask how you flipped the + and - and what you used for the glass eye? I've got an 02D car with the R59 topper and would be fun to do a similar project.
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
Old 01-13-2021, 11:34 PM
crownstables look at replie #3 posted by Jerry MacNeish on the CRG post that was linked by cruiserofland
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 01-13-2021, 11:42 PM
Matt,
I used the left over of an original cap the I had to cut off to originally use. However, the cap fit poorly (loose), so I used the repop cap that fit tight and installed the left over of the original Delco cap that I had cut.
I made the + with a plastic repair kit and simply modified the original + into a -
Hope that helps......Dave
69 Z/28 Rally Green
69 Z11 Pace Car
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
The Following User Says Thank You to luv2sixty9 For This Useful Post:
Old 01-14-2021, 12:37 AM
luv2sixty9 - Looks like I need to go with the Y55 battery. Thanks for the help.
Old 01-14-2021, 01:24 AM
flyingn's Avatar
flyingn flyingn is offline
nice work
Frank Szymkowski
The Following User Says Thank You to flyingn For This Useful Post:
luv2sixty9 (01-14-2021)
Old 01-14-2021, 01:33 AM
169indy's Avatar
169indy 169indy is offline
I did a similar conversion but Never Figured out the Pos / Neg Symbols swap, but was not concerned since the installed cable obscures it visually. Often at Swap meets you can find existing Yellow caps including the DELCO eye-cap for sale, I had spares Originals from leftover Hemmings purchased NOS batteries and harvested the Red & Yellow series Caps for future use. You have to Cut down the Eye optic center plastic eye shaft.
The Label was altered via a "Brother" label makers & some 1/2 tape w/white lettering, strategically trimmed and applied.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 2 Users Say Thank You to 169indy For This Useful Post:
cruiserofland (01-14-2021), Edgemontvillage (01-14-2021)
Tags
y55 z28 302 dz
