Old 01-27-2021, 12:05 AM
mhm1966 mhm1966 is offline
Default Holley primary metering block stamped 5271
The Holley carburetor is List-4053. The primary metering block is stamped 5271. Can anyone tell me the application for this primary metering block.
Old 01-27-2021, 12:33 AM
earntaz earntaz is offline
The 5271 was used on the pri side of 9188AAA, 3310P 3878261 EH, 3310-2S. The 4053 used a 5584 (4053P 3923289 later issue). Also 3828 was used 4053P 3923289 Possible later issue. I don't see where a 5271 was used on a 4053 ...
The Following User Says Thank You to earntaz For This Useful Post:
mhm1966 (01-27-2021)
