Old 01-29-2021, 03:19 PM
Default Help with cam number 1H284-S
Can anyone tell me what this cam is?
thanks
Old 02-01-2021, 02:22 PM
I didn't think this would be that hard. Any one know what manufacture uses those number?
Old 02-07-2021, 11:07 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Is it a Comp Cams Hydraulic 284 Dur. ? I've run that cam in the past and that looks familiar
I ain't nobody, dork.
The Following User Says Thank You to Tracker1 For This Useful Post:
chevyandpontiac (02-08-2021)
Old 02-08-2021, 04:30 PM
Could be a Comp 284 Solid cam, specs:
Mechanical Flat Tappet - Lift 0.597 / 0.606 in - Duration 284 / 293 , 258/264 @ .050"- 107 LSA - 3300 / 7300 RPM
This would be a little much for the street.
Old 02-08-2021, 08:23 PM
racer67x racer67x is offline
Isky used to number cams in a similar way also..might check there.
stock class at a local circle track the popular cam was an Isky 280H,which was hyd and about 500 lift.
its worth a shot.
Old 02-09-2021, 11:31 AM
Do you have a shortblock to throw it in? I would degree it just to be safe.
Old 02-09-2021, 12:56 PM
I think I am going to put it in the metal dumpster. Too many thoughts on what is could be, so it will be scrap. LOL
Old 02-09-2021, 01:30 PM
scuncio scuncio is online now
Is it new? Can you put it in the Tony pile? A friend of mine has a Cam Doctor...I can run it for you.
Old 02-09-2021, 05:21 PM
It is not new, but it is in nice shape and I do have the lifters also. And yes I kept the lifter is the correct order.
Old 02-09-2021, 07:39 PM
mr.4speed mr.4speed is offline
DEFINITELY A General Kinetics Cam logo
4 gear 4 life!
