Old 02-01-2021, 08:39 PM
68396L35 68396L35 is offline
Default 1969 riverside gold coupe for sale
Frame off restored # match 350/300hp #match. M-20 4-speed, ps, pdb. 1 high quality repaint on non hit body. Everything restored or replaced. New brake lines, fuel lines, fuel tank, calipers, trailing arms, sandblasted frame, control arms, then refinished in satin black. New rear spring, gas tank, all bushings, bilstein shocks, every bushing, body mounts, trailing arms, oil pan, gaskets, hoses, etc. Car doesn't leak a drop of oil, rebuilt motor, trans ,rear, half shafts, fuel tank, lines, trans, differential, all with less than 1k miles. It has high quality coated aftermarket headers that fit nicely and sound amazing. Mostly original interior remains with restored am/fm radio with modern electronics. Equipped with ultra rare speed warning speedo and tilt wheel. Car needs nothing, extremely dependable, semi survivor with mostly reconditioned original parts. 1 repaint of original color on non hit original body. Wipers and headlights are aligned perfectly and work as original. This car does not leak a drop of oil when parked for long periods of time. ultra reliable, 2 pumps of the accelerator, and it fires right up. Must see in person, top notch C3 that will only climb in value every year. Asking $31,500 or B/O. Located in central NJ. Message if interested.
The Following User Says Thank You to 68396L35 For This Useful Post:
markinnaples (02-23-2021)
Attachments - The Supercar Registry 20210206_183830.jpg 20210206_183630.jpg 20210206_183600.jpg 20210206_183535.jpg
