Go Back   The Supercar Registry > General Discussion > Ford-Mercury
Old 02-21-2021, 01:22 PM
Steve Shauger's Avatar
Administrator
Default 1971 Boss 351-Fords Ultimate Small block???
These cars were underappreciated, and out performed all previous small block and most big blocks Mustangs. Great colors, options and built to drive! The link below includes 33 pics.
https://www.hotrod.com/articles/denn...tang-boss-351/
www.yenko.net
www.vintagecertification.com
Attachments - The Supercar Registry int.jpg Ex Rear.jpg EX PS.jpg EX Ovr.jpg
Old 02-21-2021, 01:32 PM
Back in the day, I had a friend whose brother-in-law was a Powertrain Engineer at Ford in Detroit. He came home once with a silver & red 71 Boss 351 that they had 'massaged' just a wee bit Took us for one VERY impressive ride in it....wow!
Bill Pritchard
Old 02-21-2021, 02:18 PM
This was probably the strongest running small block out of Detroit.
Old 02-22-2021, 02:08 AM
My folks ordered a new Highland Green 68 Mustang GT with a gold C stripe back in the day but if I could have any Mustang I wanted it would be a Grabber Blue 71 Boss 351, what a beautiful car!
The Following User Says Thank You to carnut4life For This Useful Post:
442w30 (03-02-2021)
Old 02-24-2021, 11:06 PM
1970Bluel78 1970Bluel78 is offline
Curious? Did they make a 71 Boss 351 Convertible
1970bluel78
Old 02-24-2021, 11:54 PM
KenMaisano's Avatar
KenMaisano KenMaisano is offline
No. Only Fastback. 1806 Built.....Chrome front Bumper
No Honeycomb on the rear body panel
Standard Gas Cap
Only Four Speed with Wide Ratio
Only 3.91 Locker Rear End
DOAE-L 4 Bolt Block
D1ZX Rods and Crank
D1ZX Forged 11.5 Pistons
Solid Cam [email protected] 115 477
4V Heads with Screw in Studs 7/16
D1ZX-CA Aluminum Spread Bore Intake
D1ZF-ZA 4300D 750 Carb
D1ZE-DA Radiator
Dual Point Dist.
All Boss 351 Specific. Only.. This car was Born To Run!
On a Engine Dyno all stock but with Headers they make 375HP and 400 FTLBS
A Cam with specs of 240 110 540 and a 4779 750 Holley and your at 450 HP
The Following User Says Thank You to KenMaisano For This Useful Post:
flyingn (02-26-2021)
Old 02-25-2021, 12:42 AM
The 1971 Boss 351 is the only Boss engine (302, 351, 429) that does not use an A.I.R. pump.
Old 03-02-2021, 05:00 AM
442w30 442w30 is offline
In 1972, there was the 351 HO, which was basically a low-compression Boss 351. That engine was available in a ragtop.
