Old 02-22-2021, 11:37 AM
Copo_Cartel's Avatar
Yenko Premier Member
Default Speedo Reducer
Is there a chart out there available for speedo reducer applications and date coding. Also does a 69 Camaro with 15” tire/ 4.10 rear gear require a reducer ?? Thanks SYC .
Old 02-22-2021, 12:14 PM
TimG TimG is offline
I believe a 4.10 requires a reducer. A 4.11 gear in a Corvette does because the tail housing can't accommodate a gear big enough for a 4 series gear.
Old 02-22-2021, 12:19 PM
X66 714's Avatar
X66 714 X66 714 is online now
I can look that up but the chart starts with transmission & exact tire size...Joe
Old 02-22-2021, 12:52 PM
There's info in the Wiki:
http://www.gmpartswiki.com/getpage?pageid=12662
Click the images in the upper left and right to go forward or backward a page. 1969 is a couple of pages back.
Dates Here:
https://nastyz28.com/threads/muncie-...2#post-3551052
Owned since 1978 - First Car
Old 02-22-2021, 01:54 PM
X66 714's Avatar
Here you go Doug
http://www.gmpartswiki.com/getpage?pageid=50105
3860348 is orange w/25 teeth
3924097 is yellow w/8 teeth
Old 02-22-2021, 03:11 PM
Thank you fellas and I appreciate all of your help you guys are the best
The Following User Says Thank You to Copo_Cartel For This Useful Post:
X66 714 (02-22-2021)
Old 02-22-2021, 05:56 PM
Thumbs up
The Following User Says Thank You to BCreekDave For This Useful Post:
Copo_Cartel (02-22-2021)
