Old 03-29-2021, 11:24 PM
AnthonyS's Avatar
Default assembly line 1967 1968 Camaro SBC fan shroud 3893812 Z/28 SS350
Hi Gang, rare treat here - a correct and original assembly line SBC 302 327 or 350 plastic fan shroud. these are markedly different in appearance than the later OTC replacement parts - and they differ where it matters / most visible area at the top - the molding at the top is different and they are wider.
Thanks to Chick for the last photo posted here, copied from his mega build post at CRG, thank you! Top is the OTC unit, original below - notice the curve of the molding in the original and obvious mold marks. You want an original on your Camaro. The "caution fan" stickers won't fit on these original pieces...
There's two small drill holes in the lower clip bosses but those will certainly not be noticed / visible once clips in place and they're installed. It's off a Day 2 1968 Z that was recently parted. Don't ask. It wasn't me.
Anyway, review the photos, will likely clean up nicely or could certainly be used as-is for a survivor or driver, with or without the easter bunny.
molded in part number is 3893812
No cracks, no serious / fatal damage - some scratches and dust / dirt / grime as is to be expected on a 50+ year old part - this was factory installed.
$275 PPFF plus actual shipping & insurance.
Cheers all,
Anthony
Attachments - The Supercar Registry service replacement top assembly line original bottom from Chick at CRG.JPG IMG_5502.jpg IMG_5501.jpg IMG_5500.jpg
Old 05-02-2021, 07:56 PM
AnthonyS's Avatar
Bump TTT for this assembly line piece - the NOS OTC ones are way different and noticeable at first glance.
Thanks all,
Anthony
- I've also just gone through all my posted ads and lowered prices. Reach out if anything interests you with an offer. Cheers. Be well.
Old 06-22-2021, 03:42 AM
AnthonyS's Avatar
bump
Old 06-22-2021, 04:35 AM
Canuck's Avatar
Canuck Canuck is offline
Pm sent.
www.vancouverclassiccars.com
