Old 04-17-2021, 03:49 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Default help identifying a couple of parts please?
Hi Gang, found some parts and wanted to know if anyone can assist in identifying...
first is a chrome single snorkel air cleaner lid - stamped "front" on top.
second is a trap door oil pan - not sure it's SBC and it's been extended / welded to create a deep sump, not unlike the GM Performance OTC BBC pans that we've all seen (3879633). Driver side dip stick. Is this a SBC pan? The bolt pattern looks different, there's reinforcements in each corner. Is it a GM pan / is it aftermarket or a modified pan / one of a kind. Looks almost homemade too. That windage tray was found with it.
Any help is appreciated of course.
Thanks everyone!
Anthony
Attachments - The Supercar Registry IMG_6867.jpg IMG_6865.jpg IMG_6863.jpg IMG_6862.jpg
Old 04-17-2021, 03:54 PM
AnthonyS's Avatar
Default oil cap extension
Also found this oil cap extension - clearly NOS and the cap at least looks like original GM - with the "S" stamp for Stant I believe. Both have screw in fittings. Is this a GM piece?
Thanks again Gang!
Anthony
Old 04-17-2021, 04:20 PM
I believe the oil cap extension may be 389 Pontiac with A/C. That is just from memory so I could be off.
The air cleaner may be the same application.
Jason
AnthonyS (04-17-2021)
Old 04-17-2021, 07:21 PM
R68GTO R68GTO is offline
I think the air cleaner is 64 GTO
AnthonyS (04-18-2021)
Old 04-17-2021, 11:08 PM
rszmjt rszmjt is offline
Windage tray looks like a 64/65 Corvette 327/365 HP, except the hole doesn’t look that familiar
The Following User Says Thank You to rszmjt For This Useful Post:
