Old 05-19-2021, 09:18 PM
60sStuff's Avatar
60sStuff 60sStuff is offline
Default Early GTO oil filler caps
The Positive Crankcase Ventilation System.
The “California type PCV closed system” option K24/614 was mandatory for the first 3 years (64,65,66) of the GTO if sold “NEW” in the state of California and applied to both Automatic and Manual Shift cars.
The other 49 states did not require this #614 option on a New Pontiac, therefore making this a rather rare feature to find on a 4BBL. or Tri-Power.
In ‘64 the RH valve cover had a 2-3/4’’ high round stack to accommodate two different push on oil fill caps.
The “Sealed” AC-OIL FC-45 cap for the #614 option looked like a top hat.
The LH valve cover was flat with a rubber grommet to accommodate a black painted steel pipe which lead to the air cleaners.
The last photo shows a ‘64 GTO I owned about 40 years ago that the Original owner I bought it from changed the engine color.
The Following 3 Users Say Thank You to 60sStuff For This Useful Post:
grantprix (05-23-2021), olredalert (09-07-2021), PeteLeathersac (05-21-2021)
Attachments - The Supercar Registry FB561997-5E8D-4468-A4C8-F5E2E405743D.jpg F92E1BDD-4D99-4769-ACCE-FFF08CBA20C3.jpg F8C02FAC-FD66-4831-A7E2-68F01F0F0554.jpg F5B1F3C6-4533-49D3-888B-9167F94F1EF6.jpg
