Old 07-18-2021, 03:08 AM
Default carburetor ID
I got this Carter QuadraJet and can't figure out what it's off of. Google was no help. Can someone tell me what it is? Thanks.
Attachments - The Supercar Registry 20210718_112547.jpg 20210718_112537.jpg 20210718_112457.jpg 20210717_174943.jpg
Old 07-18-2021, 01:48 PM
John Brown's Avatar
Carter built Quadrajets for Rochester whenever Rochester needed to increase their production. Most of the time, simply adding 70 or 701 or 702 or 703 or 704 in front of the number Carter stamped on a carb they built for Rochester brings up the correct Rochester application, but it doesn't seem to on this carb.
John Brown
Old 07-18-2021, 02:15 PM
It's a Q Jet made by Carter. I'll get more pictures today. Would this be a Aug '69 carb? And the last number being even, would be for an automatic?
Old 07-18-2021, 02:39 PM
Have you cleaned and looked for more numbers in other areas? I seem to remember they would stamp on the back side too ?? Been a LONG time since I dealt with Quadrajets' on a daily basis.
I'll ask the obvious and unnecessary question...I assume the tag is gone from the cover screws ? Don't recall if Carter even used them.
Old 07-18-2021, 03:16 PM
dvss1 dvss1 is offline
67 chevy 327 or 350
The Following User Says Thank You to dvss1 For This Useful Post:
big gear head (07-19-2021)
Old 07-18-2021, 05:13 PM
A few more pictures. I didn't find any more numbers on the body. Is H9 the date?
Old 07-18-2021, 07:41 PM
Yes H9 is the date. August 69
Old 07-18-2021, 10:18 PM
The date has me confused, along with the stamp. Maybe this is a service replacement carb? If it's for a '67 application then the date is wrong. Also, the '67 Q Jet carbs that I have all have the round disc with the numbers on it like this one.
Old 07-18-2021, 11:21 PM
John Brown's Avatar
I bought a brand new service dated Rochester built q-jet for my 67 327 Caprice drag car and it had the seven digit stamped in date, not the round tag style. This was in 1973, so the carburetor also came with the later style needle and seat, thankfully.
John Brown
Old 07-19-2021, 03:37 PM
Yes it's a service dated carb .
