Old 08-07-2021, 01:17 AM
Geoff Padgett Geoff Padgett is offline
Default Day one and other aftermarket odds and ends
Hello All
I have some day two and other aftermarket stuff that's just taking up space in my garage. ----------------------$30. FOR THE ENTIRE LOT LISTED BELOW + THE RIDE ------------
. Holley dominator pull plate
. Rochester Q-jet dust cover(may fit Holley as well).
. Set of three Autometer? colored gauge light covers
. (1) blue breather-push
. (2) race style breathers
. Green line Stewart Warner water temp gauge-nice face and glass. needs to be rebuilt.
. (1) set of SB Chevy valve stem seals
. (1) set of BB/SB Chevy flywheel bolts and cam shaft bolts both have never been used
. (2) old school coil spring turn spacers(twist style)
. (4) small woodruff keys. (4) longer style woodruff keys. Not sure if these are BB/SB Chevy or Pontiac
. (1) cal custom wing nut valve cover hold down and (3) wings
. (2) valve cover oil filler hole caps, push style
. (3) Pontiac Poly lock style rocker arm nuts
. Distributor hold down, unsure what this fits
. Speedo gear reducer, looks to have been opened up. It may have been modified
. Mickey Thomson BB finned aluminum valve cover oil baffle that is held in by two screws
. Moroso BB stamped steel/Aluminum valve cover grommets. One has been cut for a push in breather the other one hasn't
. Hurst shifter knob backing/locknut
. Hurst shifter linkage bushings? (6) steel. (6) plastic- 5 are new and one is used. SOLD the clips.
. (5) plastic BB/SB Chevy oil pump shaft plastic couplers-new
. Cal custom? two wire valve cover loom
I believe I can get everything in one large USPS Flat rate box priority box @ $21.50. Payment to be made by pay pal via friends and family. Please note: The US postal service is raising their rates considerably here in the next few weeks and I can only honor that price until they raise it.
Cranberry red 1970 L-S6 hardtop
Attachments - The Supercar Registry thumbnail (65).jpeg thumbnail (64).jpeg thumbnail (61).jpeg thumbnail (60).jpeg
