Old 08-16-2021, 12:16 AM
Jims69z28 Jims69z28 is offline
Default Wanted : power steering pump and mounting brackets
Looking for power steering pump and brackets for 69 z28 restoration !
Also looking for the correct pulley 3941105 DD.
Pm please. Thanks Jim
Old 08-16-2021, 01:44 AM
ALLZS ALLZS is offline
I probley have a pimp and brackets but no deep pulley
The Following User Says Thank You to ALLZS For This Useful Post:
Jims69z28 (08-16-2021)
Old 08-16-2021, 02:08 PM
"I probley have a pimp and brackets but no deep pulley"
Is this a line from a porno?
Old 08-16-2021, 02:17 PM
Whatever you do, do not try using a repro pulley. Pure junk. I also would not consider repro brackets.
Sent you a pm.
Old 08-16-2021, 06:50 PM
William William is offline
Be aware that you must use a 1969 Camaro power steering pump, designed for variable-ratio steering. The service replacement variable ratio power steering gear was pn 3960246. It does not functionally interchange with anything; only application is the 1969 Camaro.
Chevrolet admonished against interchanging standard and VR steering components:
“The pump used on vehicles with variable ratio power steering provides increased fluid flow at higher pressure than the conventional pump. Consequently, the conventional pump and the pump used with the variable ratio system are not interchangeable. A new pump outlet hose is required on variable ratio power steering equipped cars.”
The Following 2 Users Say Thank You to William For This Useful Post:
69M22Z (08-16-2021), Jims69z28 (08-16-2021)
Old 08-16-2021, 07:40 PM
Default Power steering pump
I did not know that William. Thank you for your post
Jim
Old 08-17-2021, 12:37 AM
Default Pump and brackets
Found power steering pump and brackets . Thanks for the ad SYC
