Old 08-17-2021, 10:52 AM
F41427 F41427 is offline
Default 1967 68 302 Z/28 L78 original clutch fan
Blade has been blasted cleaned and repainted semi gloss black. Clutch has been cleaned by hand then clear coated. 100% GM clutch fan. Date on the clutch is 10-16- 67. Large hole 4 rivet blade 3 1/4" on center bolt pattern. Clutch still has smooth fluid resistance. No broken fins. Blade is straight and has the W stamped on one blade and the number 8 on the reverse side.I've had this since the mid 80s.. I can't seem to load the new pics. Please email so I can send you pictures. $SOLD
Attachments - The Supercar Registry 20210801_094645.jpg 20210725_113455.jpg 20210725_113231.jpg 20210725_113205.jpg
Tags
302 396 l78 z/28
