Old 08-25-2021, 10:14 PM
lbnaz lbnaz is offline
Yenko Premier Member
Default 70 Camaro SS L78
A car in Tucson for sale (not mine) running driving nothing original in it. Owner claims its a Baldwin Motion. I took some photos of tag, vin, and sticker. It currently is a truck 454 ALB suffix 8 digit casting number, auto, 10 bolt. Here are the photos for future documentation. Has a speed shop decal inside trunk from NJ. Has copo spoiler. Larry
The Following User Says Thank You to lbnaz For This Useful Post:
PeteLeathersac (08-26-2021)
Attachments - The Supercar Registry IMG_8558.JPG IMG_8557.JPG IMG_8556.JPG IMG_8555.JPG
Old 08-25-2021, 10:47 PM
Was also assembled in the last Month of production..Late Car!
Old 08-26-2021, 01:13 AM
Vin 124870N585615
Bill Pritchard
442w30 (08-26-2021)
Old 08-26-2021, 01:17 AM
For some reason I cannot correct the lower case letters that I posted above????? Tried 4 times.
Bill Pritchard
Old 08-26-2021, 01:31 AM
442w30 442w30 is offline
If it matters: 124870N585615
Old 08-27-2021, 03:10 PM
COPO140 COPO140 is offline
If it matters to anyone, I did pull the NCRS shipper data on the car. It's a Reedman car. Thought folks may want to know.
Old 08-27-2021, 03:39 PM
owners2 owners2 is offline
Any more pictures.
Old 08-27-2021, 04:35 PM
Default photos
Here are a few the owner sent me. Larry
Old 08-27-2021, 04:45 PM
Curious that the trim tag rivet hole doesn't line up, nor does the "shadow" under it. Could the rivet remaining be that loose to allow this ? LOS body with Norwood tag ?? Were the tag hole spacing's different ?
Old 08-27-2021, 05:48 PM
L16pilot L16pilot is offline
Although the trim tags were different dimensions in '70 between Norwood and Van Nuys, the rivet holes were the same dimension and location, so the upper Cowl panels must have included the TT rivet holes when stamped at the supplier...not as the assembly plant.
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
