Old 09-04-2021, 01:25 PM
scuncio scuncio is offline
Default '68 L-79 El Camino
Neat truck - claimed to be the 'matching numbers' 325hp engine but these days, without a picture of the deck, you just never know.
I'm of the opinion that every El Camino should have a bench and 4-speed, as this one does....
Link to 1968 L-79 El Camino auction
136808B155788
The Following 5 Users Say Thank You to scuncio For This Useful Post:
dykstra (11-19-2021), L78M22Rag (09-05-2021), markinnaples (09-07-2021), olredalert (09-04-2021), PeteLeathersac (09-04-2021)
Old 09-04-2021, 02:08 PM
67since67's Avatar
Long water pump and spin-on oil filter on a '68? That usually means engine swap....
The Following 2 Users Say Thank You to 67since67 For This Useful Post:
dustinm (09-05-2021), L78M22Rag (09-05-2021)
Old 09-04-2021, 02:49 PM
Except the heads don't have accessory holes. Looks like someone just wanted to convert to the 69 style ps pump and alternator mounting.
If you ever tried running a passenger side alternator on an engine without the accessory holes, you will know why someone fabbed a mickey mouse bracket set up for the lower alt mount bolt on this car.
He probably added ps, and could not find the correct ps pump mounting brackets. They are vary scarce. All the lower HP engines used a different set up. On my 68 El Camino, to run and 8 inch balancer, I had to modify the ps bracket to clear.
The Following 3 Users Say Thank You to Lynn For This Useful Post:
dustinm (09-05-2021), L78M22Rag (09-05-2021), Pat C (11-17-2021)
Old 09-05-2021, 01:14 AM
The LWP crossed my mind too...good eye on the non-accessory-hole heads.
Old 09-05-2021, 02:37 PM
----Had to cut the radiator shroud for clearance! It would seem to me that 68 Corvette power steering stuff would have filled the bill and be relatively easy to track down.....Bill S
Old 09-05-2021, 02:41 PM
67since67's Avatar
Point taken and good catch on the cylinder head bolt holes Lynn! It's beyond my comprehension why anyone would swap to LWP, unless just using parts available?
Cutting the lower ps bracket for 8" balancer clearance would be much easier than mickey mousing an alt bracket IMO.
Old 11-17-2021, 03:33 AM
Relisted in the link below, and currently at $6500 with the reserve not met.
