Old 09-12-2021, 02:13 PM
XXXGoldL34M20's Avatar
Arrow 1969 1970 "SURVIVOR" Two Speed 5044681 Wiper Motor Assembly Many Models
Original assembly line two speed 5044681 Wiper Motor Assembly.
Tested and works great, I regreased the inside only and used a small wire brush to lightly get rid of dirt and grime. The 4918070 Cover is not cracked which also has the original "Yellow" ink stamped date code and part number still showing, Original White/Biege 3 line plastic squirter assembly still uncracked, clear 4918077 Delco Remy Casting # on the back. Original survivor Foil Label with 5044681 090 9 A1 (March 31 1969 First Line Shift). Label can be peeled off to add a correct date for your car but I wanted to leave the original there to show location. It will be very hard to find a nicer "Survivor" motor that came off a 1969 Chevelle with very low miles. Comes with a new set of mounting screws. Unit also has the correct original Ground Strap.
$325 USD with FREE Shipping to USA or Canada. Paypal "Friends"
Old 10-08-2021, 06:40 PM
SOLD on FB
