Old 01-23-2022, 06:05 PM
Default Solid Lifters w/ EDM Oiling Wanted SBC
I am looking for a set of EDM Small Block Solid Lifters w/ Oiling Holes if anyone has a set they aren't currently using? Seems they are backordered and I could sure use a set if anyone has a spare, or a set that could be replaced later? Happy to buy them outright, trade for them, or replace them once they become available again?
Comp #800-16, Isky SO202H or I would also use Howards EDM series or Crower / Lunati Cool Face Lifters. Anyone?
Old 01-23-2022, 07:47 PM
L_e_e's Avatar
L_e_e L_e_e is offline
I've used the Crower EDM solid lifters in a couple of my builds and never had a problem with them, great choice for a solid lifter motor. Also, I inspect them under a magnifying glass and measure them prior to installation and they all have been perfect.
I'll check with my buddy, he usually has a couple sets on the shelf.
The Following User Says Thank You to L_e_e For This Useful Post:
NorCam (01-24-2022)
Old 01-23-2022, 08:14 PM
If you have a standard set you may consider taking them apart and finding a local tool shop with a "hole popper" EDM. I had a set done and it took about an hour and it was 100 bucks. Its the same process Crower and Howards uses.
You can even do it on a set of used lifters that have been broke in to the cam. Just mark the lifter to the lobe.
Owned since 1978 - First Car
The Following User Says Thank You to BCreekDave For This Useful Post:
NorCam (01-24-2022)
Old 01-25-2022, 06:25 PM
L_e_e's Avatar
He does not have any and has been waiting on an order to come in, said it shouldn't be much longer, I can let you know when they arrive.
NorCam (01-25-2022)
Old 01-25-2022, 07:05 PM
What size is the hole and where is it located? I have access to a hole popper and would like to do a set that I'm installing in a big block now.
Old 01-25-2022, 07:57 PM
Some are on center and some are offset a quarter inch. Different thoughts on what is best. I put 0.018 diameter holes on center in mine. Howards does a 0.021 diameter. Crower does 0.024 or 0.012. Comp Cams does 0.012
0.018 is about equal to a 1/16" diameter open hole in the oil system.
big gear head (01-26-2022)
Old 01-25-2022, 11:55 PM
Lots of chatter about the size of the hole making a noticeable difference on oil pressure? I like the comp EDM lifters but they've been wiped out (pardon the pun) on lifters for over 18 months. Most of the lifter stock comes from one of the big two cam core manufacturers and these things have been on backorder with most companies (Isky, Comp, Lunati, Howards) for well over a year now and it isn't going to get any better for a while yet so I am told.
