Old 03-07-2022, 12:13 PM
GBowman GBowman is offline
Default 69 Front Caliper Restoration
Looking for tips/processes on restoring 69 front calipers. Is it safe to bead blast, etc....? Basically looking for the do's and do not's since I haven't restored a set. Thanks in advance.
Attachments - The Supercar Registry tn_10013304.JPG tn_10013301.JPG tn_10013280.JPG tn_10013271.JPG
Old 03-07-2022, 12:57 PM
RPOLS3's Avatar
RPOLS3 RPOLS3 is offline
You might consider having your local NAPA store rebuild them, then all you have to do is paint them when you get them back. They will rebuild your originals pretty economically.
Jake Dykstra
Dykstra Motorsports
bbbentley (03-07-2022)
Old 03-07-2022, 02:02 PM
SS427's Avatar
SS427 SS427 is offline
Extremely easy to rebuild though a parts washer and bead blast cabinet helps a lot. I do all of ours here and they are not difficult at all and only takes a couple of hours. The seals are the tricky part if you have never done them before.
However and like Jake said, you can have them done pretty inexpensively.
Rick Nelson
The Following 5 Users Say Thank You to SS427 For This Useful Post:
mhm1966 (03-08-2022), MosportGreen66 (03-08-2022), RPOLS3 (03-07-2022), Steve Shauger (03-07-2022), Xplantdad (03-07-2022)
Old 03-07-2022, 02:06 PM
scuncio scuncio is online now
Nice pics. Is the outside diameter of the piston coated, or just machined to spec?
Old 03-07-2022, 02:09 PM
SS427's Avatar
Yes they are plated. I believe it is a chrome type plating (not like a bumper). You can buy replacement pistons cheap.
Rick Nelson
The Following 2 Users Say Thank You to SS427 For This Useful Post:
RPOLS3 (03-07-2022), scuncio (03-07-2022)
Old 03-07-2022, 03:51 PM
Where can I find the pistons and seal kits? Thanks.
Old 03-07-2022, 04:01 PM
X66 714's Avatar
X66 714 X66 714 is online now
Just about any parts store. Most of the time you won't need pistons....Joe
Old 03-07-2022, 05:00 PM
rlw68's Avatar
rlw68 rlw68 is offline
Free shipping if you have Prime
https://www.amazon.com/Raybestos-DPS.../dp/B000C73E0E
https://www.amazon.com/Raybestos-WK5.../dp/B000CPIGPY
https://www.amazon.com/Raybestos-H55.../dp/B000C75NEY
Rob
The Following User Says Thank You to rlw68 For This Useful Post:
Old 03-07-2022, 11:23 PM
Billohio Billohio is offline
I got my parts at NAPA. That seal can be a challenge to get started straight
Bill
