Old 03-15-2022, 05:29 PM
jwcarguy jwcarguy is offline
Default 1969 Camaro SS396 X66 project car
We have a 1969 Camaro SS396 " X66 " code car that we have decided not to build as we have a couple others
This car was originally Frost Green paint code 59
has 12 bolt w/ 5 leaf spring
included are big block engine mounts
big block 4 speed transmission crossmember
no engine or transmission
was manual disc brake, manual steering car, but included is a power disc brake booster, master cyl and prop valve setup and power steering box
This car has had 90% of metal work done on it, (professional shop) which includes:
-new full floor pan
-new quarter panels
-new outer wheel wells
-new dash panel
-new rear cowl
-new rh cowl
-extra trunk lid (firebird on car)
-extra upper cowl vent panel
-SS Hood w/ chrome trays
will need:
-bodywork completed
-trunk floor repaired/ replaced
-two window channel repairs (one in front upper left, one rear rh side)
-couple dents in rockers pulled out (one each side)
Included parts:
has all factory tinted side glass pieces
front and rear seats
stock dash carrier w/ speedo and fuel gauge
some original interior pieces
steering column
clutch and brake pedal
e-brake pedal assembly
big block heater box
door internals
door and quarter window regulators and tracks
original fuel lines and brake lines
some original seat belts
front and rear bumpers
front grille w/ headlights and bezels
wiper motor and transmission
some big block parts ( pulley and brackets)
rear tail light assemblies and valance lights
boxes of hardware
Has new:
- OER Dash Pad in box
-Under Hood Insulation Kit
have available for additional cost:
-69 ' 427/335hp (LE code) engine " 512" block casting #, w/ 67' #215 casting closed chamber heads (long block w/ oil pan, balancer, flexplate and exhaust manifolds)
-72' Muncie M20 4 speed transmission
asking $28,000 for car and parts included (no engine or trans) SOLD!!
pm/ call/ text (702)677-4085
in Las Vegas, NV
more pictures available upon request
Attachments - The Supercar Registry thumbnail_IMG_1088.jpg thumbnail_IMG_1084.jpg thumbnail_IMG_1081.jpg thumbnail_IMG_1080.jpg
Old 03-17-2022, 08:11 PM
sold!!
The Following User Says Thank You to jwcarguy For This Useful Post:
Mike L78 (03-26-2023)
