Old 03-15-2022, 06:29 PM
jbtech's Avatar
jbtech jbtech is offline
Default 1967 Camaro L78 Parts List
Hello everyone. I'm slowly hoarding parts for my 04D 1967 Camaro 396 L78. This post will be modified as the needs change.
I like the idea of driving the car as is until all the parts are found and God willing the original engine is in my garage before beginning a correct restoration.
Parts Wanted:
RH A Pillar Molding (Bright) 7657638
Positive Battery Cable 6289139 ZM
Negative Battery Cable 2987212 XP
Window cranks 2 needed 7680653
Standard Seat Belts + Hardware
Decklid Dated T14, T15, or T16
Trunk Mat
Speedometer Cable Clips
Assembly line 1967 Battery Tray
Radio Block off Cover 3893845
Down the line:
Radiator
Shroud
WT Stamped Master Cylinder 5460346 Dated near Booster and Valve (82, 75)
Dated Gas Tank
Original Fuel Sending Unit
NOS GM Control Arm Bushings
NOS GM Body Mount Cushions
Fan Clutch
Shocks
Original Mono Leaf Springs
Parts Found:
September '66 4.56 Ring and Pinion
No Date 174 Carrier
7C Voltage Regulator
66M Heater Core
Black Surrey Sun Visors
67 Survivor Valve Covers
1100693 Alt
3844100AK pulley
SS Hood Dated week 14
SS Hood Louvers
Dash Pad
LH A Pillar Molding 7657639
SS Gas Cap
SS Emblems
Parts Pending Found:
Original GM Interior panels + Arm Rests
Jose Betancourt
67 Camaro L78
The Following User Says Thank You to jbtech For This Useful Post:
SuperNovaSS (03-16-2022)
Old 03-15-2022, 06:37 PM
AnthonyS's Avatar
Yay!
Old 03-15-2022, 10:09 PM
302moz 302moz is offline
Default 67
Is this a LA car or Norwood?
Old 03-15-2022, 10:48 PM
jbtech's Avatar
Norwood
Jose Betancourt
67 Camaro L78
Old 10-17-2022, 02:49 AM
jbtech's Avatar
Unfortunately I'm not able to edit my original post so here is the update:
Parts Wanted:
Holley 3910 724 or 732 date
Standard Seat Belts ALL (January Date?)
Shroud
Dated Gas Tank
Fan Clutch
Shocks (NON F41)
(1) original gm rear shock plastic cap
NOS weatherstripping (ALL except Driver door)
NOS Oil line kit for L78+gauges
Parts Found:
January '67 174 carrier
No Date 174 Carrier
66M Heater Core
1100693 Alt
3844100AK pulley NOS stamped
SS Hood Louvers
Dash Pad
SS Gas Cap
SS Emblems
Radiator OL IL (March) + UN Tag + Shroud Clip
Original GM Bright A pillar moldings
Rolled Loop Salmon tip short dipstick
3.25" bp 4 rivet fan H W stamps
Pending:
Original GM hardware
NOS black package tray
Thank You!
Jose Betancourt
67 Camaro L78
Old 10-24-2022, 10:07 PM
TerryD's Avatar
TerryD TerryD is offline
Sent you a pm regarding the neg batt cable and carb.
Old 10-25-2022, 12:02 AM
jbtech's Avatar
PM Replied. Thank you!
Jose Betancourt
67 Camaro L78
Old 01-18-2023, 03:03 PM
jbtech's Avatar
Unfortunately I'm not able to edit previous posts (so annoying). I'm very thankful to have found some of the most difficult parts thus far.
Parts Wanted:
Driveshaft with non-offset U Joints 50.46" center to center of U Joint
3913415 carb throttle return spring black, 4.24" long, and 40 coils
Original GM Positive Battery Cable 6289139 ZM
637 Shroud (I have a service one with both 637 and later part number)
NOS weatherstripping (ALL except Driver door weatherstrip and RH door outer window felt)
Shocks (I believe fronts are same as F41 and rear standard? I need to double check)
1967 Big Block starter solenoid wiring retainer
T14-T16 1967 GM decklid (one that hasn't had a spoiler added)
Partial list of Parts Found:
Dated Standard Seat Belts (from 4C date car)
Original GM Negative Battery Cable 2987212 XP
Original Muncie Speedo cable clips
Assembly line original battery tray+hold down+e head bolt
Complete front disc brakes, gas tank,8515 booster (identical "82" date), WT master, metering valve, brake lines (from 4C L30 M20 (4P) car)
Complete original glove box door with original identical sticker (from 4C 4N car)
Body Mounts complete set
Complete Holley 3910 731 date
Original correct Schwitzer fan clutch and spare 4 rivet 3.25bp fan
7D Voltage Regulator
66M Heater Core
67C Heater Core
1100693 Alt
SS Hood Louvers
Dash Pad
SS Gas Cap
SS Emblems
Thank You!
Jose Betancourt
67 Camaro L78
