Old 04-10-2022, 05:49 PM
bergy's Avatar
bergy bergy is offline
Default 1967 12 bolt rear
This rear was in an old drag car. According to the assembly stamp, it started life as 3.55 posi. It does have the traction bar bracket. I took the cover off, and this is what I found. Just judging by turning the pinion - I'd estimate 4.88 gears.
dykstra (04-13-2022)
Attachments - The Supercar Registry rear.jpg rear 12 bolt 4.88.jpg rear 12 bolt 4.88 3.jpg rear 12 bolt 4.88 2.jpg
Old 04-13-2022, 04:39 PM
Ring gear interesting with the corner breaks and deburring . No other mfg stamping on ring gear?
68,69&2015 Z/28's
Few Corvettes
Old 04-13-2022, 06:11 PM
That's also going to have c clip eliminators on it.
MarcDant (04-15-2022)
bergy's Avatar
No other marks that I can see. I need to take it apart.
Old 04-13-2022, 07:30 PM
8 teeth on the pinion, count the teeth on the ring gear and divide by 8... 39 on the ring will get you 4.875
bergy (04-13-2022)
Old 04-14-2022, 07:02 PM
Kurt S Kurt S is offline
QP is a 3.07 posi, with metallic brakes. First one I've ever seen.
Kurt S - CRG
Old 04-15-2022, 11:07 AM
bergy's Avatar
I think Jim Stubbings has had a couple. This one has been modified - perches removed, tubes welded to housing. Not much pitting though.
