Old 04-15-2022, 09:02 PM
Default 69 Chevelle Turn Signal Cancel Cam Replacement
I'm replacing the turn signal cancel cam in the steering column of my 69 Chevelle. This part is also a part of the horn contact connection. The original piece has some grease on the forward facing side, where there's a metal ring that is part of the horn connection. That grease is all hardened after 53 years (not surprising). Anyone have knowledge as to what type of grease I should use on the new piece? Looks like that same grease is on the contacts in the turn signal switch also.
Bill Pritchard
