Old 04-19-2022, 01:14 PM
outlawperformance outlawperformance is offline
Default 1969 Double Engine Stamp?
I'm curious about this one I know some strange things happened in the factory. It appears a gang stamp was used and the numbers have consistent spacing. Could this just be a factory double stamp? or someone trying to hide something?
Thanks Steve
Attachments - The Supercar Registry F72EBFAD-CE81-4721-AC93-76F0A42AFC97.jpg cranescorvette.jpg 67 pad 17062 Pat Sullivan real double stamp.jpg 1969-chevrolet-nova-ss.jpg
Old 04-19-2022, 01:55 PM
Gang stamp,not gain.
Old 04-19-2022, 02:48 PM
Formula455SD Formula455SD is offline
My SD455 is double stamped from the factory.
Old 04-19-2022, 02:50 PM
----Do you have the opportunity to take the paint off the tab? My old eyes would be able to help more. We need to see the broach marks as well!....Bill S
MosportGreen66 (04-19-2022)
Old 04-19-2022, 06:49 PM
Stefano Stefano is offline
Double Stamps / bounced stamps in themselves are not uncommon. I have seen 2 and even three of the same stamp, once on a transmission.
Old 04-19-2022, 09:48 PM
TimG TimG is offline
I have many, many double stamps in my pad library, this is one of my favorites because you keep trying to focus on it as it appears blury. This is a confirmed original stamp correcting a 9 to a 6. It should have been ground and restamped correctly.
napa68 (04-20-2022)
Old 04-20-2022, 12:21 AM
Crush Crush is online now
Originally Posted by TimG View Post
I have many, many double stamps in my pad library, this is one of my favoirits because you keep trying to focus on it as it appears blury. This is a confirmed original stamp correcting a 9 to a 6. It should have been ground and restamped correctly.
Out of curiosity, how do you confirm a double stamp?
Thanks
Old 04-20-2022, 12:44 AM
It would go through a Regional or National NCRS event or Bloomington Gold. Any stamp with a question will go to a higher authority. They would look at stamps with an exact same build date and assembaly code and look for VIN numbers surrounding the stamp they are looking at.
The Following 6 Users Say Thank You to TimG For This Useful Post:
Big Block Bill (04-21-2022), Charley Lillard (04-20-2022), Crush (04-20-2022), dykstra (04-21-2022), napa68 (04-20-2022), olredalert (04-20-2022)
Old 04-20-2022, 03:25 PM
MarcDant's Avatar
MarcDant MarcDant is offline
Default stamping and broach
Tim are you familiar with cranes corvettes .The w on the first post is different then others i have seen.
Old 04-21-2022, 12:15 AM
David C. David C. is offline
I’ve got this block out of one of my cars. Must have been the new guy.
https://www.yenko.net/forum/attachme...1&d=1650500001
Dave C.
