Old 05-15-2022, 04:11 PM
earntaz earntaz is offline
Default Cleaning aluminum intake
I have an old BBC Weiand aluminum intake that needs serious cleaning. I'd like to get it back to the original finish as possible. Any suggestions from the members? Thanks ... Craig
Old 05-15-2022, 05:27 PM
soak it in a 50/50 solution of simple green and water for 24 hours. Wash with water and a brush, blow it dry with compressed air, then let it sit over night. Next take a steel bowl (or glass) and put 1 cup of lacquer thinner then spray Krylon Dull aluminum spay paint in the top of the lacquer thinner. Lightly brush the solution on the intake and let in dry. the thinner dries and the Dull Aluminum soaks into the manifold. It might take a couple of try to get it done the way you want it DO NOT Blast it.
Bill
The Following 2 Users Say Thank You to Big Block Bill For This Useful Post:
earntaz (05-15-2022), mhm1966 (05-15-2022)
Old 05-15-2022, 06:09 PM
BCreekDave BCreekDave is online now
Might check around to see if anyone local does "Vapor Blasting" AKA vapor honing. Motorcycle restoration shops have been doing this for awhile now and its gaining popularity for cars. It uses a very fine abrasive in a water slurry and does not change the texture at all.
Owned since 1978 - First Car
The Following 2 Users Say Thank You to BCreekDave For This Useful Post:
earntaz (05-16-2022), mhm1966 (05-15-2022)
Old 05-15-2022, 06:11 PM
L_e_e's Avatar
L_e_e L_e_e is offline
I've also have had good luck using a Mag Wheel cleaner, use the one for non clear coated wheels.
The Following 2 Users Say Thank You to L_e_e For This Useful Post:
earntaz (05-16-2022), scuncio (05-15-2022)
Old 05-15-2022, 08:33 PM
fiveforty fiveforty is offline
Spray it with wheel acid then blast it with a steam cleaner when the water gets up to temp.
The Following 2 Users Say Thank You to fiveforty For This Useful Post:
earntaz (05-16-2022), napa68 (05-16-2022)
Old 05-16-2022, 06:23 PM
1972convss454 1972convss454 is offline
Vapor Hone is the way to go. It will look brand new.
Joseph Farrow
1970 Chevelle L78
1970 Chevelle LS6
1972 Chevelle LS5
The Following User Says Thank You to 1972convss454 For This Useful Post:
earntaz (05-17-2022)
Old 05-16-2022, 09:12 PM
cruiserofland's Avatar
cruiserofland cruiserofland is offline
Mine came out great just using carb cleaner and white cloth rags (or plain white cotton t-shirts), plus q-tips for the finer areas.
~Matt
'69 Z/28 RS
'77 F100
'83 FJ60
'10 WC50
‘24 J250
The Following 2 Users Say Thank You to cruiserofland For This Useful Post:
earntaz (05-17-2022), SPEEDYB (05-22-2022)
