Old 07-03-2022, 07:41 PM
AnthonyS's Avatar
AnthonyS AnthonyS is offline
Default 1967 1968 Camaro rear bumper
Hi Gang, I have this rear bumper available. It's off an old / retired racecar.
I believe it will fit 1967 or 1968 cars but also understand that there may be little nuances between those two years vis-à-vis assembly line units versus OTC replacements. Two brackets still attached and two bolts broken off - I'm sure these are just the square tang carriage bolts and I just didn't bother to whack them out. This is what it is. Several detailed photos below for full picture.
Good, straight CA core for rechroming or even using as-is if you like.
And yes, that is rubber on the corners - likely deposited there at the timing lights decades ago... instant street cred if you install this before heading downtown Friday night.
Just $100 PPG plus the shipping - it won't be cheap to ship I would bet.
Cheers all,
Anthony
Attachments - The Supercar Registry IMG_0672.jpg IMG_0671.jpg IMG_0670.jpg IMG_0669.jpg
Old 07-18-2022, 04:37 AM
AnthonyS's Avatar
Bump. Is someone here able to give this stray bumper a forever home?
