Old 08-15-2022, 02:07 AM
hays2441 hays2441 is offline
Default Value of 1969 z/28
Came across a 1969 Camaro Z/28 RS that I was able to go see and decode today. I am going to try to best describe the car and see what the experts here can give me on a range for price.
Original Olympic Gold Paint with Black Vinyl Top
Protecto Plate
Car is a late December build 12D
Car was a one owner until recently purhased.
Flat hood no spoiler
The car has the original drive train, engine, trans and rear end. Stampings all visible and all align with the build date of the car.
All components appear to be correct and original..... based on dates I reviewed today. This includes carb, dist, alternator, radiator, master brake cylinder, starter, YH rims...the only thing that I don't think is original is the power brake booster. Car has headers but the exhaust manifolds and smog were all kept by the original owner. Interior is black standard and should clean up well. So basically a very original car.
The weakness of the car is that it does have some rust in the usual places.
Front fenders have some of the usual rust in the lower area down by the cowl. I believe these could be patched if one wanted to keep the original fenders.
Rear quarters behind the rear wheel have rusted through and will require a patch or quarter replacement. Also looks like that one if not both of the trunk drops will need to be replaced.
Trunk has some surface rust but no evidence of it being rusted through and is very solid. The car has the usual dents and scratches for a car of this age.
Car also has some rust around the bottom inside of the front windshield and I believe the metal dash will need to be replaced.
Seller sees the car as a survivor, however I see the car as very original and should be restored. Car has some rust as called out but overall very solid.
Looking for some thoughts around pricing based on the information that I have provided. Thanks in advance for help that can be provided.
Scott
Old 08-15-2022, 03:13 AM
TMagda's Avatar
TMagda TMagda is offline
With the info provided I would say between $15,000 and $35,000. Start at $80k and work backwards to the WIW price. Are all the original parts there? I think the market is softening a bit for all but the best cars. Its going to be hard to get buyers and seller together for a while. I am helping someone sell a 69 Z/28 right now and I can see its not going to happen due to expectations.
Old 08-15-2022, 05:43 AM
COPO COPO is offline
Two very important items you didn't mention is whether the car runs and drive well and is it original paint or a repaint? Regardless, in this market I'd say at least $40K and up.
Old 08-15-2022, 05:44 AM
Two very important items you didn't mention is does the car run and drive well and is this original paint or a repaint? Regardless, in this market I'd say at least $40K and up.
Old 08-15-2022, 12:52 PM
Thanks for the quick response. All number match on the driveline and I think all if not most of the components are original and have correct dates. Original paint car with some
rust in the lower front fenders and lover rear quarters behind the real wheel wells. Car has been parked since 1980 and does not run. RS Z/28.
Old 08-15-2022, 01:26 PM
Depending on how bad the rust is I would say 35K.
The Following User Says Thank You to Charley Lillard For This Useful Post:
purple panther (09-03-2022)
Old 08-15-2022, 01:27 PM
How many miles on it ?
Old 08-15-2022, 01:30 PM
William William is offline
Any attempt to 'patch' rust will destroy the cars' originality. Replacing the rusty dash top with the poor repro is always detectable and requires removing the VIN tag. Breeching the original installation can result in a state-assigned VIN label with corresponding decrease in value.
Best plan for this car is to re-install all the original components, clean it up and get it running. Do not ruin the car with a 'cowl' hood and spoilers.
At a show, it will be the Z/28 with a crowd around it, admiring the originality.
The Following 11 Users Say Thank You to William For This Useful Post:
427TJ (08-16-2022), 60sStuff (08-16-2022), 67 Nova Boy (09-01-2022), 67since67 (08-15-2022), 69M22Z (08-15-2022), jerry455 (08-15-2022), PeteLeathersac (08-15-2022), ruralrte66 (08-16-2022), SPEEDYB (09-02-2022), Steve Shauger (08-15-2022), Xplantdad (08-15-2022)
Old 08-15-2022, 01:51 PM
RALLY RALLY is offline
Totally agree. Detail from head to toe and clean shampoo interior and clean underneath the car. Wax, buff detail and drive to shows and drive around town. That is what i would do.
Old 08-15-2022, 07:37 PM
Agree, clean it up and get it running and you will draw a crowd. No need to restore if it has original paint.
The Following User Says Thank You to COPO For This Useful Post:
