Old 08-16-2022, 03:16 PM
X66 714's Avatar
X66 714 X66 714 is online now
Default 40727 396 A/C fuel pump info request
Looking for information on 40727 AC fuel pumps. Trying to see what 2 letter date codes were used. 2 letter codes were used prior to 1971. In 1971 AC went to a Julian code date system. Trying to help with research. Thank you Joe
Old 08-16-2022, 04:19 PM
bbjohnny bbjohnny is offline
I have a 261J40727. It doesn't have the two letter code but was manufactured in 1970, but would be 1971 production.
The Following User Says Thank You to bbjohnny For This Useful Post:
X66 714 (08-16-2022)
Old 08-16-2022, 06:03 PM
Pacecar1969 Pacecar1969 is offline
Default Fuel Pump Date Codes
First letter is month. Second is year EI then would be May, 1969
The Following User Says Thank You to Pacecar1969 For This Useful Post:
Old 08-16-2022, 11:09 PM
Diamond_Don Diamond_Don is offline
I have BJ40727.
Using Pacecar1969 decode method this should translate to February, 1970.
The Following User Says Thank You to Diamond_Don For This Useful Post:
Old 08-17-2022, 02:06 PM
X66 714's Avatar
I guess I didn't ask my question correctly. I'm looking to see examples of known 40727 fuel pumps with a 2 letter code. As indicated A,B,C, etc in the 1st spot is the month & the 2nd spot is the year. H=1968, I=1969, J=1970. If you have one with this type of code, I would like to heare from you. I'm not looking to purchase, just information please. So far I have a BJ40727 with is Feb 1970. Thank you for that Don....Joe
