Old 01-03-2023, 06:58 PM
earntaz earntaz is offline
Default 454 cam recommendations.
I need some guidance from the experts in sYc. I have a 454 that I want to retro fit a hydraulic roller cam setup into it. The motor is fresh rebuild with nearly everything new. The CR is right at 10:1. The block is a 3999289 from a 73’ truck. The front of the block has the two threaded holes on each side of the cam … Thrust plate mounting? The heads are 3931063 with 2.19/1.88 valves and LS6 valve springs … they have been port matched and slight bowl work. I have full length headers into a 3” system. I have a Weiand intake and 3310-2 carb. I am putting the motor in a 70 Nova w/TH-400 and slight increase in converter stall. Rear gears are 3.42 posi. The Nova will be 95% on the street and a shot at the strip to see what it’ll turn. One of the cams I have been looking at is the factory HO454/502 hydraulic roller … good? With all that being said I need suggestions. Thanks all!
Old 01-03-2023, 07:31 PM
Probably get as many opinions as there are a holes.
If you want an off the shelf item, I would call Eric Jackson (VintageMusclecar).
http://www.vintagemusclecarparts.com/
If you are willing to go custom, contact Chris Straub at Straub Technologies.
https://straubtechnologies.com/
These guys deal with so many different combinations that they will have insight that most won't. A friend that happened to have a good / bad experience with a particular camshaft may not have the exact same combo you are putting together.
Sounds like ton of fun in a Nova.
earntaz (01-03-2023), jerry455 (01-06-2023)
Old 01-03-2023, 09:33 PM
dustinm dustinm is offline
Yes make use of the thrust plate/holes and use a GenV step nose cam - makes it very easy for the swap. I like Bullet Cams they have all the UDHarold designs, just use the best hyd rollers you can get.
The Following 2 Users Say Thank You to dustinm For This Useful Post:
69M22Z (01-03-2023), earntaz (01-03-2023)
Old 01-03-2023, 09:34 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Default camshaft choice...
I have used the GM BB hydraulic roller 502/502 cam in the 454 HO motor...it runs good and makes decent power. Pretty sure we had to use a specific distributor gear??? Aluminum heads with bigger valves and we have an Edelbrock Performer RPM, 750 or 800 Holley, TH400 with ATI convertor.
Hope that helps...
As mentioned, Eric is a good guy to run these deals by...he can help!!
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
The Following User Says Thank You to WILMASBOYL78 For This Useful Post:
Old 01-03-2023, 10:52 PM
Hope that helps...
-wilma
Wilma - was that the 12366543 or 24502611? Thanks ... Craig
Old 01-06-2023, 03:11 PM
Thanks Wilma ... I'm sure I will need to use a thrust plate instead of the cam button. My block is already drilled and has 1/4" tapped holes on the front of block next to the cam. What roller lifters did you use? ... Craig
Old 01-06-2023, 06:03 PM
Post Camshaft...
We used the 502/502 cam...#543
Not sure about the lifters, most likely used the stock units that came with the 454HO motor. I do recall we added Eddy aluminum heads...couldn't get the small chamber [100cc] ones, so we milled the larger ones to help raise the compression...this required special pushrods.
Overall the motor runs and sounds great...pretty good power for what it is.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
earntaz (01-06-2023)
Old 01-16-2023, 08:38 PM
VintageMusclecar's Avatar
Tom, Lynn, thanks for the plug.
I can help with either a shelf or a custom grind camshaft if you're still looking. My contact info is in my profile.
Eric
Old 01-17-2023, 12:02 AM
Didn't even consider it a plug. I just know you always have taken care of me on my projects.
VintageMusclecar (01-17-2023)
