Old 01-04-2023, 01:11 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Default Mallory Rev Pol ZC310HP sbc & bbc
Just finished going through this one. Very clean piece and everything was disassembled, cleaned and moly lube applied to wear surfaces. Points are set to 0.012” and both condensers working from my ohm resistance testing. Body was cleaned to original finish and only item clear coated were the condensers. This was to help seal where the mini cracks are starting to appear. Vacuum advance with a very clean puck, new gasket and advance weights left at their factory setting. What you see is what you get. Bushings looked brand new. Distributor rotor is a good original as well as the cap. Inner bladder is still original 7mm as is the top. $475 plus shipping.
1st photo is of before condition.
Attachments - The Supercar Registry E7AAB998-C74C-4979-B37B-26D37CB98A67.jpeg DF1415BA-00B5-46EE-A94C-15974FFB0E18.jpeg B3FEF9E1-3210-4148-B5FB-F1BB2EBFCB2E.jpeg 8D2A7CB3-CC28-4A98-ADE1-C4D8316213C3.jpeg
Old 01-04-2023, 08:45 PM
BJCHEV396's Avatar
Wow,great piece and nice job cleaning it up!
cook_dw (01-05-2023)
Old 01-05-2023, 07:24 PM
cook_dw's Avatar
Pending.
