Old 02-07-2023, 03:00 AM
169indy's Avatar
169indy 169indy is offline
Default Reproduction tapered carb studs
For Sale; Background, I removed my Original Studs from my 1968Z intake to send to a plater for refinishing only to have them LOST by the provider. So I reverse engineered the studs using a fine commercial starter stock. I machined (Lathe work) the Dog Point (Turned down Tip) as per Original samples then glass beaded and sent them off to a different zinc plater for ATSM B38 Zinc Type II yellow chromated, wire hung plating.
Dimensions: 1.50" Nom Length overall, 11/16" effective 5/16-UNF, 5/8" effective 5/16-UNC, 5/64" Dog Point (UNF END), Mfr Dimple on the UNF End, Wire hang mark on the UNC end that will be installed in the Alum Manifold. Studs are tested for free running threads, Ready to Install.
40$ + Shipping (From 98311) per Set of Four (4) studs.
69 Los Z11
68 SS/RS 396/325
68 Los Z28
The Following 4 Users Say Thank You to 169indy For This Useful Post:
69M22Z (02-07-2023), Hawkeye (02-08-2023), TerryD (02-08-2023), Zman1969 (02-07-2023)
Attachments - The Supercar Registry DSC03872.jpg DSC03871.jpg DSC03870.jpg DSC03869.jpg
